Hi lads noticed a bit play in my rear Roam 40 wheel. Is it much of a job to replace the bearings ?
Daz
Posted : 18/02/2020 7:49 am
Not really...
bearings - 1 x 6903 (17x30x7) and 3 x 17x28x7
Posted : 18/02/2020 9:39 am
Did mine recently for Roam 30's, assuming it's similar. Knock out the bad bearing and, if you don't have proper tool, use the old one as a buffer to tap the new one in so that it takes the brunt.
Posted : 18/02/2020 9:42 am
Excellent thank you very much for your help 👍🏻👍🏻👍🏻
Posted : 19/02/2020 7:46 am
Are the sram roam hubs the same as hope as the bearing kits specify both ? Also the bearing kits only come with 2 bearings ?
Posted : 19/02/2020 7:55 am
There's two bearing in the wheel and two in the freehub.
Posted : 19/02/2020 1:38 pm
Thank you mate. I’ve ordered the 4.
Posted : 20/02/2020 11:34 am
