sram road and mtb c...
[Closed] sram road and mtb compatability
[#3198495]
Trying to work out bes way to get a low gear on the cross bike. I assume sram x7 mech will work with rival double tap shifters.
Will the 10 spd rival shifters work with a med cage 9 spd mech or only with a 10 spd x7 mech
ta
Posted : 30/09/2011 10:45 am
SRAM 10 speed stuff is cross compatible. 9 speed is different.
So you can use the Rival shifters with the 10 speed X.7 mech, but not a 9 speed one.
Posted : 30/09/2011 10:47 am
cheers for that
does anyone know if the med cage rival mech will strecth to take 36 tooth rear cassette?
Posted : 30/09/2011 10:50 am
No, you need an MTB mech to do the 36.
Posted : 30/09/2011 10:54 am
Could you just get a smaller double chainset? Maybe like a Middleburn Duo?
Posted : 30/09/2011 12:32 pm
its for a new build and toying with eiterh 34-50 sram chainse tthat i have enarly new and going for a 32t out back but noticed teh 1030 11-36 cassette that is steel cogs on alu carrier that i think should last reall well
or change the chaniset ot an x5 double on 28 42 and buy a tiagra 12-30 cassette to run with the med cage rival mech i have. just worried that 42 12 will be a bit small on the road sometimes.
hopefully sram will bring out an 11-32 1030 cassette soon
Posted : 30/09/2011 1:17 pm
You mean like most cassettes 😕
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=55201 ]Hardly bank breaking[/url].
42-12 top gear is not high on the road at all, IMO you'd spin that out annoyingly easily and spend all your time at the top of the block. 28-30 is also a fair bit lower than 34-32. If you went for the 28/42 chainset you'd definitely want an 11-up cassette I'd say, but even then I'd not choose it.
What exactly are you trying to achieve? Assuming this is a normal road bike are you worried 34-32 isn't low enough!?
Posted : 30/09/2011 1:39 pm
no tis for a cross bike but to use on the hils of teh north lakes for some long steepish climbs for training. Having seen teh link u posted though i'll be going that way with the 11-32 cassette and cpmpact chainset
cheers
Posted : 30/09/2011 2:31 pm
