SRAM powerlink
[Closed] SRAM powerlink
[#6745918]
I must be missing something, but how do you undo this? I've tried pushing together but doesn't budge.
Posted : 03/01/2015 4:41 pm
You need the pliers or to get needle nose pliers on the plate edges to squeeze them together. Finder pressure probably won't do it.
Posted : 03/01/2015 4:48 pm
Some can removed them by hand, the tool makes it much easier: http://www.chainreactioncycles.com/park-tool-master-link-pliers-mlp1-2/rp-prod109888
Posted : 03/01/2015 4:50 pm
Pointless, throw them away and get some KMC Missing Links instead if you want to be able to easily remove your chain.
Posted : 03/01/2015 4:57 pm
Not all SRAM links are quick fit, some are semi permanent Powerlink?
Posted : 03/01/2015 5:03 pm
 kcal
They can - sometimes - be done by hand, with a lot of flex of the chain, twist, push together.
But the pliers are *much* easier 🙂
Posted : 03/01/2015 5:05 pm
the 10 speed Powerlinks are supposed to be one-use only, but i've been using one for a good few applications and it's still good. I use the special pliers to remove.
Posted : 03/01/2015 5:15 pm
removed sram by fingers frequently basically pushing, flexing ,wiggling and patience and reused
pliers after that
could not get the KMC to move with hands or pliers or the might of the divinities
Posted : 03/01/2015 5:30 pm
Assuming 9spd here but piece of p1ss! Grip between thumb and finger and squeeze in opposite directions. Doesn't need a lot of pressure, it's more about pushing the plates in opposite directions. Unless the chain is utterly manky in which case it might want a blast of gt85
Posted : 03/01/2015 8:04 pm
Ok great thank you to all. Will try the squeeze bit first and then probably buy the pliers! 🙂
Posted : 03/01/2015 10:18 pm
8/9 speed ones are reusable. 10/11 speed aren't. They can be done with the pliers, but they're not designed to be undone, and to do so by hand is near impossible. The Superstar pliers are a good purchase IMO.
Posted : 03/01/2015 10:26 pm
