Sram pg970
[Closed] Sram pg970
[#3422596]
Anyone know if this [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=57562 ]Cassette[/url]has an alu carrier?
I like quite a tight ratio cassette like an 11-27/28 however I now have a hope pro 2 rear hub and my current cassette is cutting into the alloy freehub body, I am hoping that the above cassette will meet my requirements but if not can anyone suggest a cassette that does?
Posted : 03/12/2011 4:30 pm
I'm pretty sure the 970 isn't on a carrier. You can get Shimano SLX in 11-28, but that only has the 3 biggest rings on a carrier.
Posted : 03/12/2011 5:02 pm
The pg970 isn't on a carrier.
Posted : 03/12/2011 5:16 pm
b,
Have a look for a 9-speed Ultegra CS6500 12-27.
It has 2 alloy spiders to spread the load.
Dura-Ace is the same, but the budget may be stretched a little.
If you want 9-speed with 32 or bigger, you can get an XT M770.
Posted : 03/12/2011 6:50 pm
Thanks for the help, I already have an ultegra cassette and it is still cutting in due to the fact that some of the gears are still loose. I may try an XT as it has been a while since I used a larger cassette and I may like it now, although this theory never worked with broccoli :(, my riding has changed since I last owned an 11-32.
Posted : 03/12/2011 8:18 pm
