I think I need to repalce my drive train - starting to get chain suck. The chain is 0.75% worn, so I'm tempted to try repalcing the chain only - but suspect the chain suck means the chain rings themselves are too far gone...... So considering replacing the whole lot simultaneously.
BUT cash is currently tight as. I have a Hope pro 2 hub so want to use an alloy cassette carrier to avoid gouging the free hub too badly - and looking for the cheapest option here!
NO - 990 has alloy carrier
Edit: and pg980 🙂
from memory you will need the 980 rather than the 970. On-one were doing both in their clearance section last week at good prices.
have a good look at the rings, chances are just one or two teeth have burrs, file the burrs off and you're good to go, new chain only should be fine.
Thanks guys - Donk will give that a go!
@clanton - I combined 2 knackered cassettes for a mate and as donk says burred off the hooks with a file and he's been riding it with a new chain for 5 months now!
PG990s on offer atm on CRC.
only £40 if you're man enough for the pink one!!
