Anyone used one? Is it reliable? niner apparently aren't supplying the PF30 bio-centric except in 24mm spindle compatible as had been previously thought, so herself's new bike needs a BSA insert.
Posted : 13/12/2014 5:22 pm
Bearing fit it in and you don't have to fit the cups before you install it.
Was fine in my Mamasita.
Posted : 13/12/2014 5:24 pm
Posted : 13/12/2014 7:47 pm
Mine tended to 'walk' out slightly on the driveside. Others with the same issue had loctited it in (not sure which product). I swapped to a kcnc adaptor instead.
Posted : 13/12/2014 7:54 pm
Gee - that'd be cool,are you at the. Brass Monkey tomorrow? I'll drop you a line a bit later. We'll be riding the 4 hour in M & F Vets....
Posted : 13/12/2014 8:22 pm
YGM back again...
Posted : 13/12/2014 9:18 pm
