The ball bearing jockey wheels in the sram xo mech are just not up to northern mud and keep seizing - are there any aftermarket alternatives that are better sealed or use bushings?
Lower range SRAM jockey wheels use bushings not bearings so more robust - much cheaper too
Been using some Uberbike ones for a while and they have been far better than the SRAM ones they replaced
Try pulling the seals out the bearings and filling with a good quality marine grease
Just grease them
yes, I've re-greased them but I've done that before and just wondered if there was a more durable alternative. Last time I looked uberbike didn't do 12T ones but I see that do now so i'll give those try. Cheers.
I use stainless bearing tacx jockey wheels from decathlon £9 ish. Last well for me and simple 5 min job to repack. The smallest bearings I have ever seen in my life came from a shimano jockey wheel. I gave up all ideas of putting back together.
I use the cheaper GX versions, seem to last ok
