Sram GX level narro...
[Closed] Sram GX level narrow wide chain ring options?
[#7420565]
Looking for 30t 94bcd. Sram rings seem to be X01 at about £50.
Are there cheaper compatible alternative s? Uber bike looked hopeful, but their narrow wides are 104bcd.
Thanks
Posted : 28/10/2015 2:22 pm
 rone
I might have a spare 30t 94bcd sram X1 - coming off my new bike.
Not sure what you're after paying?
I've paid anywhere between £50-65 quid for rings. The bigger ones being more expensive.
Posted : 28/10/2015 2:36 pm
I had to go for sram when I replaced mine as I couldn't find any alternatives.
I do have an X1 30t that I would sell, it has 10/15 rides on it - email is in my profile if you are interested.
Posted : 28/10/2015 3:10 pm
I'm also after a 30t guys so if the Op doesn't buy form you I could be interested….
Posted : 28/10/2015 3:36 pm
Go to CRC, click on MTB, click on chainrings, drop down bolt circle filter, filter for 94 bcd, there's everything from steel SRAM for £16 to X01 for £50 via absolute black oval ones for £34.
HTH
Does it matter if it states Boost 148 compatible?
Posted : 28/10/2015 3:45 pm
Rone, interested in a swap for my 32t
Posted : 28/10/2015 3:46 pm
Changes the chain line by 6mm I think. You could always use the CRC page as a guide to what's available and then go directly to the manufacturers web sites to see if they do different versions for boost and non-boost, assuming that the difference isn't built into the cranks.
Posted : 28/10/2015 3:49 pm
 rone
Agent - I've already ordered a 38T for this particular bike.(rigid lightweight commute bike) Thanks anyway.
I will see what we end up with from the shop, as we're buying two bikes so essentially two 30t's left.
Should know by end of week.
Posted : 28/10/2015 4:39 pm
Wow, 38t! I've ordered from CRC now - so have a 32t ring to sell
Posted : 30/10/2015 3:25 pm
