SRAM Guide caliper ...
[Closed] SRAM Guide caliper catching on rotor?
[#7614203]
Just fitted some Guides - on the rear the caliper is catching on the rotor
I'm using a Centreline rotor 160mm with a Shimano IS to Post mount 160mm adaptor
It doesn't seem to matter how I adjust any of the mounting bolts
Do I just need to shim the caliper a bit further away from the rotor?
Posted : 30/01/2016 3:05 pm
Not sure what you mean, is the calliper sitting to low and hitting the top of the rotor or do you mean hitting the mount adapter?
Posted : 30/01/2016 3:34 pm
hi - yes the former
Posted : 30/01/2016 3:37 pm
shim it I would say depends how much height difference or an avid 165 mount if sram are still awkward with giving things an extra 5mm
Posted : 30/01/2016 3:41 pm
ok that's worked only concern is that top part of pads are not in contact with rotor when brake applied
Posted : 30/01/2016 3:47 pm
sitting up too high now? that will cause some problems when the pads wear.
Posted : 30/01/2016 3:52 pm
yeah a few mm too high
think it could be the horizontal dropouts causing the issue
Posted : 30/01/2016 4:04 pm
What frame is it? You're not using a front post mount on the rear on anything crazy like that?
Posted : 30/01/2016 4:14 pm
Krampus
Posted : 30/01/2016 5:49 pm
