I'm planning to change the inner and outer gear cable on my Eagle drivetrain. Do I need to to use sram stuff or can I use shimano? I already have some so would save me buying more. Ready sram is 1.1mm and shimano is 1.2mm cable, thinking if you used as a pair, ie shimano inner and outer it wouldn't be an issue?
I've used Shimano and jagwire on my setups from memory so I reckon you'll be ok.
I’ve used the Clarks gear cable kits with the black Teflon coated inners and whatever tyre outers are for Shimano 105 11 speed road shifters, Sram Rival 10 speed road shifter and several different sram 10 & 11 speed mtb shifters. Can’t imagine there would be any drama between gear cables for Sram Eagle.
