SRAM double tap roa...
[Closed] SRAM double tap road levers?
[#1076264]
One for the roadies really.
Just building up a new road machine and am thinking of going the SRAM route (rather than Shimano) for a change.
Is anyone using SRAM double tap road levers? If so any real world reviews - any good?
thanks
Posted : 26/11/2009 2:52 pm
I'm not a real roadie but got em and like em (SRAM Rival). Double tap is a really poor description of how the levers work in my opinion. Real description of how double tap works:
1. If you push the lever gently until you feel a click (and resistance increase), then release, you will shift to a smaller sprocket.
2. If you push the lever gently until you feel a click, but carry on pushing further, you will shift to a bigger sprocket. You can change up to three sprockets in this direction if you throw the lever far enough.
I think it works really well. Some people don't get on with it, but the general consensus seems to be that it is a a decent alternative, not really better or worse, just different. Shouldn't take long to adjust.
Also, SRAM Rival as a groupset is a bargain. The 09 version was lighter than Dura Ace, good ergonomics and shifting performance, and similar price to 105.
Posted : 26/11/2009 3:18 pm
yeah i've got some on a boardman bike. they're light, but not as smooth and nice to use as shimano. The double-tap thing is very quick to get used to though.
Posted : 26/11/2009 3:26 pm
I like mine, I though i'd got it dailed straight away with only a few mis-shifts. But now i've got 6 months use it's like second nature...
Posted : 26/11/2009 4:10 pm
 SiB
+1 to all the above, sram rival. Seem to be a bit noisy but that could be to do with carbon frame amplifying sound? No complaints
Posted : 26/11/2009 4:23 pm
Had Shimano for about 6 months and now have had SRAM (Rival) for about the same. I prefer double tap, I like that the brake lever is always in the same place! On the downside though, if you ever dropped your bike or came off, I reckon the 'able to move inwards' Shimano brake lever would hold up better than the fixed SRAM.
Posted : 26/11/2009 4:45 pm
I have RED and wish I'd bought Dura Ace. Brakes are good, it is light, but the shifting is a bit too fussy and I still mis shift even after a year of using it. Perhaps it's just me.
Posted : 26/11/2009 4:49 pm
I have tried the flat bar version and found that to be very easy to use once i had got how it worked in my head worked out and would put it on my mtb if i could aford it and they did 9 speed.
Posted : 26/11/2009 4:53 pm
