Does anyone know when the CX1 Hydraulic groupset will be available? I've been trawling the internet and can only find a little information.
Just looked on the Fisher trade website, it's all listed (with prices), arrival TBC.
Cheers Njee, I'd seen that as well. It was more the release date I was after.
I'm also a little confused about the 10 speed and mtb RD compatibility.
Will just have to be patient
Well yes, but the release date is just conceptual isn't it, what you need is the date you'll be able to get your hands on it, which is still TBC.
Although actually that's not quite true:
Shifter - TBC: £86
Rear mech - TBC: £178
Chainset - some permutations in stock (BB30 170mm cranks), others TBC: £157 - £189
Brakes - 5th October: £305 each
Chain rings - some in stock, others due 29th September
Chains in stock
So brakes are the stopping point (pun intended), unless you can find an alternative source.
Rear mech not compatible with 10 speed, but compatible with XX1 I
believe, why you'd bother though, not sure?
Cheers for that, was looking for a potential cheaper option for the rear mech.
Looks like it will be into the cross season before it's in the shops.
chasinabeeinacar - Member
about two weeks before the recall
badoom-tish
about two weeks before the recallbadoom-tish
