I have just taken off GX Eagle crank and realised that the 10mm self extracting bolt was turning while I was turning the 8mm bolt. I nipped up the 10mm bolt and the crank came out fine. What torque should the 10mm self extracting bolt be? Can't see that in the SRAM manual, just the torque for the 8mm. Should I take out the 10mm and apply some loctite (looks like there is grease in there)?
Posted : 26/08/2018 7:42 pm
id just pinch it up with a bit of loctite on it. as long as it doesn't fall out you'll be right, its the 8mm that does the work.
Posted : 26/08/2018 8:59 pm
Will do, cheers.
Posted : 26/08/2018 11:42 pm
