Could I use a GXP chainset in a BB30 frame?
(or vice versa?)
Are the chainsets the same and just the bb itself is of different dimensions?
You can get an adaptor to fit GXP chainset (22/24mm spindle) into a BB/PF30.
Other way round - doubtful, you'd need bearing cups that could fit in a BSA threaded frame and take a 30mm spindle.
EDIT - Rotor do one:
[url= http://www.chainreactioncycles.com/rotor-bsa-30mm-steel-bottom-bracket/rp-prod130466?gs=1&utm_source=google&utm_term=&utm_campaign=Chain%20Reaction-UK-PLA-PLA-All-DT-SE-Shopping%20QLB%20Generic%20Desktop&utm_medium=base&utm_content=mkwid%7CsrSsZx1dW_dc%7Cpcrid%7C161850070953%7Cpkw%7C%7Cpmt%7C%7Cprd%7C468578UK ]http://www.chainreactioncycles.com/rotor-bsa-30mm-steel-bottom-bracket[/url]
Okay thanks for that sounds like it should work
A BB30 won't fit a BSA shell with external bearings - Rotor BSA30 cranks have a longer spindle. GXP into BB30 not a problem.
Ta, good to know only works with Rotor.
