SRAM axs issue
SRAM axs issue
[#13145945]
Charger displaying blue light 👍
No other LEDs on 🤔
Battery not charging as far as I can see??
It was fine last charge (or so I thought) but the change only held for 2 rides and flat as a fart mid ride tonight!!
Anyone had this? I'll be into SRAM tech tomorrow
Posted : 07/02/2024 8:59 pm
Check if any of the pogo pins have failed. It'll look something like this;
IMG_6222
Posted : 07/02/2024 9:03 pm
Clean the contacts on the battery with electrical contact cleaner.
Mine did this recently, cleaning the contacts sorted it
Posted : 07/02/2024 9:04 pm
@doomanic the issue is in the charger buddy but will have a look at that
@julians I'll give that a go - cheers
Posted : 07/02/2024 9:14 pm
I know the issue is with the charger, the pic of my mech was for reference so you know what to look for...
Posted : 07/02/2024 9:42 pm
Different charging cables used? Or a different plug? Mine works brilliantly if I use a phone charger plug and usb cable. If I use a 3 usb port plug and usb cable then it won't charge - even if it is the only thing plugged in to the 3-usb port plug.
Just asking as I had this problem and it was fixed by using a single usb plug.
Posted : 07/02/2024 10:10 pm
Charger fine
Cable usual
Tried @dickbarton no joy
Posted : 08/02/2024 7:51 am
Sounds like a duff battery then. I have one that I was convinced was fully charged but when I came to use it, a month or so later, it lasted 30 mins before giving a low battery warning. Virtually new battery with 2 charge cycles at most.
Posted : 08/02/2024 8:25 am
duff battery.
my mates did the same. he thought it was the charger, tried mine, same result.
i have one that last about 30 mins then dies.
its at the end of its life. new battery required.
Posted : 08/02/2024 8:27 am
It's less than 10 charge cycles old
Posted : 08/02/2024 9:39 am
checked the charger - swapped for another - still not working
definitely the battery - hello zyrofisher
Posted : 08/02/2024 10:18 am
ah apologies, assumed it was an old battery.
They should replace under warranty without any issues.
Posted : 08/02/2024 3:09 pm
