SRAM and long days ...
[Closed] SRAM and long days (shifting issues)
[#4349170]
I'm no weed, but after four days I couldn't use the front mech because shifting was so hard. Anyone else had this?
The shifter seems to need a massive shift, so I tightened the cable which did shorten the shift, but made it very very stiff.
I'm going to have a good look at it soon, but the massive shift, about 50mm to make it click seems ridiculous.
The rear mech shifter is very sweet though.
Posted : 10/09/2012 9:18 pm
Sticky cables? Clean out the cables and shifter with some GT85 or similar
Posted : 10/09/2012 9:26 pm
Cables probably.
I've run X9 shifters for years and they're pretty reliable, but as with Shimano, it's worth giving the cables a once over every now and again.
My front mech isn't a full length outer so it tends to stiffen over time. I don't really notice as it's a gradual process, but it gets to a similar state to the OP's before I either strip and service or replace the cables.
Posted : 10/09/2012 10:50 pm
I'm assuming you're on about road shifters. Are you sure the cable is routed/clamped into the front mech correctly? It should just go straight in behine the bolt like this:
Posted : 10/09/2012 10:58 pm
I need to check that.
I do manual work, and tour riders change gear for weeks, but after four days and 550 miles my finger tips couldn't operate the shifter.
Posted : 11/09/2012 6:32 am
