SRAM 11 speed casse...
[Closed] SRAM 11 speed cassettes
[#7597424]
So I've convinced myself that 11 speed is a good idea and have since got a good price on a shifter and rear mech. Sourced a freebie body for my wheels from the states and decided on a kmc chain the last piece in the puzzle is a cassette.
Whilst I'd love the XX1 version I'm not sure I can justify its price over the X1 version question is is there really going to be much performance difference between a gx, X1, x01 or xx1 cassette? Then the other spanner in the works is the e.13 cassette which gives an even larger range but is a bit unknown. Any real world experiences would be welcome.
Posted : 23/01/2016 12:33 am
Weight difference buy very little else. Have GX and XX1 and both are really impressive bits of kit, but at different price points. Id avoid the E13 as it has too.many alu cogs
Posted : 23/01/2016 12:42 am
Personally unless you are really watching the grammes then the GX is the best value.
Posted : 23/01/2016 3:45 am
The e13 cassette only has alu cogs in the upper section, the ones least susceptible to wear. But also don't forget the cassette splits in two with either of these two sections available separately meaning that you're not throwing a whole cassette out because you've worn the 11 tooth out (for example).
Also, the e13 cassette offers a 9 - 44 range so the ratio is wider than anyone else on the market.
Posted : 23/01/2016 4:43 am
 DT78
It's all about 12 speed now...
Posted : 23/01/2016 7:50 am
For most people, the upper half of the cassette is the part that's most susceptible to wear. Making it out of aluminium is just going to accelerate that. Also judging people's opinions of the wear rate of e13 expander rings, well, you better get used to changing bits, a lot.
The amount of SRAM 11 speed cassettes I've seen that look fine other than a doggy 42t seems to tally with that.
Shifting performance doesn't seem to vary much on all the cassettes, but the one huge benefit to the XX1 example is it doesn't look like crap after a handful of muddy rides. Why people think black cassettes is a good idea is beyond me.
Posted : 23/01/2016 8:29 am
Maybe, maybe not. It's horses for courses and is going to be heavily dependent on the rider and what size ring they're running st the front.
What is a fact though is that small sprockets will wear faster than bigger.
Still, eitherway the point still stands, whichever you wear out first you can buy a replacement of that half of the cassette, as such so example of SRAM cassettes being fine other than a worn out 42 is a great 'real-world' example.
Posted : 23/01/2016 9:53 am
If you want to keep costs down an xt 11-42 is considerably cheaper. 10% range difference though. I've put one on for winter and will go to a gx in the spring
Posted : 23/01/2016 9:57 am
richiethesilverfish - Member
I tried using Alu cogs (the Absolute Black 4 cog expander) and it was awful. The lowest gear was ok but the ones below.just disappeared.on me. Was slipping under load within a month. Aku just.isn't the right material for cassettes.
SRAM 42t can be replaced. And if you have to have Alu,the cog with most teeth and w lowest load us the place to have it.
Posted : 23/01/2016 10:05 am
I keep meaning to take some photos but I have a complete brand new GX transmission to sell, if anyone wants a bargain!
Came on my Bird Zero AM but I took it straight off and put on the used 1x10 stuff I already have (our hills are small, I have strong legs and this is also my commuter bike so I'd rather not grind a posh cassette into the ground...)
Posted : 23/01/2016 12:40 pm
12 speed, blimey what will they think of next!
Posted : 23/01/2016 1:00 pm
ianfitz - Member
My GX was 109 Euro including chain. Very little price difference to XT (plus wider range and loghter).
Posted : 23/01/2016 1:16 pm
Also... that E13 is 320g
GX at a third of the price is only about 50 or 60g more
Posted : 23/01/2016 1:35 pm
I could be interested in this. I'm looking to go 1x11. I'm about to buy XT but am curious. I need: shifter, mech, cassette, XD driver (?Hope Pro2 Evo compatible?), chain, 104bcd 32t.
email in profile
Posted : 23/01/2016 3:03 pm
do you have a link?
cheers
Posted : 23/01/2016 7:51 pm
cheers HG 🙂
Posted : 23/01/2016 9:53 pm
For better looks and price....n and no need for an XD driver, go XT.
If you really want that bit of extra range, go GX.
One bike has gx cassette here, the other XT. Mainly due to one rear wheel not having an XD driver available for it.
That said, the shim XT cassette looks quality. The GX.... Well, it didn't look nice after the first few rides that's for sure.
As someone said, black cassette? Why? ?
Posted : 24/01/2016 5:03 am
How many is a few? Been on since october and doing just fine, needs a little clean but staying black.
Seeing as the GX is lighter than the XT, not far off in price and in reality you will only need to buy one XD driver ever as any new wheel will come with the option (except shimano) I'd take the GX every time.
To me the XT looks like they forgot to remove all the excess metal from the prototype which does account for it's impressive weight vs function.
Posted : 24/01/2016 5:12 am
Chief groove guru, I'm interested in the Gx stuff for my fatbike, email in profile too ...
Posted : 24/01/2016 6:18 am
mikewsmith.... I think your definition of staying black is different to mine to be honest.
The simple point is the XT cassette by definition will never change colour from wear and tear for obvious reasons. The GX Will.
The black coating is a side issue anyway, I prefer the GX cassette as I do like the slight increase in range
Just a shame it isn't silver.
Posted : 24/01/2016 6:48 am
lol the non black bits are dust, really can't be bothered to was it until it rains properly here!
Posted : 24/01/2016 8:47 am
the cheaper cassette - otherwise you will be reluctant to go for a ride in the mud for fear of wearing it.
Posted : 24/01/2016 9:22 am
mikewsmith - Member
Dust, dust! !
What is this dust you speak of!? 😀
Posted : 24/01/2016 9:24 am
Obviously doesn't ride in the UK in any remotely muddy conditions then.
There is a 3 month old warranty replacement X01 cassette on my wife's bike that's probably been ridden 8 or 9 times. It looks visually f*cked.
6 month old XX1 cassette - barely looks used by comparison.
Black cassettes are a silly idea. But then I think they also look crap when new. Just slightly less crap.
Posted : 24/01/2016 12:11 pm
Started its life in mud, seen a fair bit just been dusty recently. I tend to give my kit a hard life and it seems to last 🙂
Posted : 24/01/2016 12:18 pm
dust
[1000yd stare] dust... [/1000yd stare]
Posted : 24/01/2016 1:16 pm
Honestly the dust is getting too much, grip is suffering, it's hard work unless your in the front of the line up and all that, plus a good chuck of the island is still on fire. Hoping for some good rain this week.
Posted : 24/01/2016 1:19 pm
