Sram 10 speed XO c...
[Closed] Sram 10 speed XO cage swap on newer mechs?
[#4585072]
Can it be done like the old 9 speed XO rear mech type just by one 3mm bolt then twist cage= spring then off..?
Posted : 23/11/2012 4:03 am
Yes! Although it's a bit different to the 9speed mechs. On the 'knuckle' (to which the cage is attached to) you'll find a clip - pull this up and out. Then undo the 3mm tension bolt , twist the cage and remove.
Posted : 23/11/2012 9:50 am
ah.wondered what that clip was for does it just clip,push back in then mate.
Many many thx pal..
Posted : 23/11/2012 5:07 pm
