Squelshing noises f...
[Closed] Squelshing noises from my rear shock?
[#3692065]
Suntour Epicon RL 140mm.3 years old.The shock seems to still be working.Noise of liquids moving about.Small leakage of odourless oil.Do you think i,ve broken the seals?Or is it shot.Rebound,compression and lockout still working.It also still holds its air well.Thanks for any help in advance.
Posted : 18/02/2012 9:54 pm
I would say it needs a service mate, new seals
Posted : 18/02/2012 10:06 pm
My RP23's just gone back to Mojo for the same thing, cavitation or summink. Nitrogen getting into the oil. It only came back in December after the same fault, done about 3 rides then stood for 5 weeks, bounced it up & down on Thursday to hear 'squelch squelch squelch'
Posted : 18/02/2012 10:13 pm
At the very least;
take the shock off the bike
write down/remember what shock pressure you had/run it at
empty all the air out the shock
unscrew the 'air can' (the fatter part of the shock body). Likely you'll need a strap wrench for this though
clean everything you can
put a bit of suspension grease on the shaft and seals
screw back together
pump back up (likely youll need a shock pump if youve not got one)
refit shock to frame
should get rid/reduce the noise for a bit. Most likely won't help the oil(/air?) leak though
Posted : 18/02/2012 10:54 pm
It,s never had a service,where would I send a Suntour airshock if i can't service it?Thanks for your answers.Wonder if I damaged the seals in the freezing weather?
Posted : 18/02/2012 11:34 pm
I had this on my Fox RP23 too, tried self servicing it, but made no difference, so sent it back to Mojo and it's been right as rain ever since... Mine only did it with the Pro pedal on tho'
Sorry can't help with Suntour servicing places, try Mojo first they might know who does.
Posted : 18/02/2012 11:48 pm
Anybody know who services Suntour shocks in the uk.Cheers.
Posted : 19/02/2012 1:32 am
