Squealing SLX
[Closed] Squealing SLX
[#4901410]
Trek Remedy, 2012, running an SLX brake on the rear with 180mm rotor. I have changed the pads(twice),the rotor(three times)and ALL the bolts,but it still lets the world know when I`m braking.
Is this a problem other people have suffered?
Anyone got a SENSIBLE solution?
Posted : 24/02/2013 5:59 pm
Hope
Posted : 24/02/2013 6:06 pm
Bad luck. I used to try various things such as cleaning rotors with alcohol, taking pads out and sanding gently etc. now I just take the pads out and hit them with a blowtorch until they stop giving off their own flame.
No idea if it is safe or not but works for me ( xt brakes btw)
Posted : 24/02/2013 6:24 pm
weaping seals?
Posted : 24/02/2013 6:26 pm
Exactly the same problem as me.
[url= http://singletrackworld.com/forum/topic/brake-problems-contaminated-rotors ]Some interesting answers here.[/url]
Posted : 24/02/2013 6:36 pm
No fluid leaks.....No rotor contamination....
Posted : 25/02/2013 9:40 am
try a small amount of copper grease between the pads and calipers.
worked for my mono minis
Posted : 25/02/2013 9:46 am
Good tut here: http://www.pinkbike.com/news/Tech-Tuesday-Silence-That-Squeaky-Disc-Brake-2011.html
Seems bedding them in from new probably helps
Posted : 25/02/2013 4:26 pm
