Squeaky Lefty hub
[Closed] Squeaky Lefty hub
[#1806320]
New wheels. After less than 20 miles, front hub making a continuous irritating squeaking noise. Should I be worried (eg. about incipient bearing failure) or is this normal wearing-in?
Andy
(Have emailed shop too, before this is suggested)
Posted : 16/07/2010 6:06 pm
when mine started doing this it turned out to be a thin nylon washer that sits under the cap on the outboard side that has the bolt going through it you use to attach the wheel.
I just removed the cap (reverse thread) and liberally greased the washer on both sides, noise went away and 2 years later still hasn't returned 🙂
Not saying 100% that's what yours is, but that's what it was on mine...
Matt
Posted : 16/07/2010 7:38 pm
Grease the bit that sticks out at the bottom from the Lefty where the inner surfaces of the hub bearings are in contact.
Posted : 16/07/2010 7:42 pm
Thanks - I'll give those a try.
Andy
Posted : 16/07/2010 8:02 pm
Which wheels did you get in the end?
I fell for those SLRs on Merlin.
Posted : 16/07/2010 8:11 pm
Yep, me too. Too good a bargain to pass up; existing DT rims in need of truing so swapped tyres, rotors & cassette over.
First go on them today as crashed doing the Towneley & lots of shoulder pain, which is mended enough to go riding now. They feel quite fast, squeak notwithstanding.
Andy
Posted : 16/07/2010 8:25 pm
Everything given a good greasing & the problem is solved. Thanks all.
Andy
Posted : 20/07/2010 1:33 pm
Bit of a hijack,
Are the lefty SLR's from merlin the latest ones are a couple of years old? ie do they have the full on 3d interspoke milling, or just the original only between the spokes?
Its a really temping offer!
Photos of them on a bike always appreciated 😉
Posted : 20/07/2010 2:20 pm
Can't post a phot as my bike is utterly caked in clart & the STW photo jury will have me for that 😛
They're the 2008 wheels, which means the original milling (painted black), sadly. However, I still think they're a bit of a bargain - this year's Crossmax STs seem to be about the £600 mark, and I don't think you could get a decent handbuilt set for £300.
Andy
Posted : 20/07/2010 2:33 pm
