Hi - My RP23 is squeaking about a month after it was serviced. I am pretty sure it is the bushings. If I loosen the pivot bolts, the squeaking stops, but when tightened correctly (or just to remove play) it returns.. The bolt washers have worn into the busings a little, could that be it? I have cleaned it all up but that hasn't helped...
Thanks
Posted : 28/07/2012 8:49 pm
grease it?
Posted : 28/07/2012 9:04 pm
I will for now - but I keep reading that you're not supposed to (to avoid grit getting in and wearing it all out I think)..
Posted : 28/07/2012 9:33 pm
