square taper proble...
[Closed] square taper problems?
 ton
[#5431637]
always used square taper bottom brackets when possible (when doing self builds), so that's is a lot of bb's over a lot of years.
built a new tourer a couple of months ago, used a un26, which I know is cheap but usually ok, it died in 6 weeks
fitted a un54 about 3 week ago. feels loose already and squeaks/creaks like buggery.
any idea's?
finger is poised over the buy button for a new xt m780 set up
Posted : 16/08/2013 8:46 pm
Had a UN26 die on me within 4 months too
Just fitted a UN55 to replace it so see how long that lasts
Posted : 16/08/2013 9:20 pm
 ton
dodgy batch perhaps?
Posted : 16/08/2013 9:35 pm
I had issues with my square taper on my commuter.
The non-drive side crank arm bolt kept coming loose.
Tightened it loads until I got pi**ed off & removed it to inspect.
Turns out the 'square' part of the crank arm was far from square 🙁
New Hollowtech 2 setup soon followed.
Posted : 16/08/2013 9:40 pm
I too used the old set up till I found out that the crank interface had stretched and no big torque would keep the bolt or arm held in place. time to get modern on it. 🙂
Posted : 16/08/2013 9:43 pm
 ton
modern stuff now ordered from crc.
Posted : 16/08/2013 9:46 pm
Might be - I'd put it down to maybe cross threading the NDS cup and perhaps throwing it offline / not supporting the bracket properly (ie user error in installation)
I'd be happier if it wasnt my fault tho
Creaking is a fit issue, not related to BB itself
Posted : 16/08/2013 10:40 pm
In my experience, squeaks and creaks are often the crank arms worn and moving slightly.
What happened to the first one? Can't imagine them failing in 6 weeks. Those and cockroaches will be the only things to survive a nuclear war.
Posted : 16/08/2013 10:46 pm
alandavidpetrie79
Same issue I had a few times. Worked out it was partly because I ride with left foot forward when coasting, which is acting against the thread direction of the bolt.
Gave up in the end, went HTII.
Posted : 16/08/2013 10:47 pm
