Sprocket top hat wa...
[Closed] Sprocket top hat washer play
[#9886858]
Hi,
I just got a new front sprocket (Stolen cartwheel) for my BMX. I noticed the top hat washer doesn't fit tight into the sprocket, there's just under a mm play between the sprocket and the washer. So when it's on and I turn the sprocket the chain goes from tight to loose, at the same point in every revolution.
Should there be play between the washer and the sprocket like this?
Posted : 12/03/2018 3:46 am
