Spraying steel fram...
[Closed] Spraying steel frames help
[#440016]
OK so Im thinking about stripping a very old steel frame and re painting not too worried about getting it done by a pro more a DIY garage attempt...
can it be done with aerosols and be a reasonable finish????
Do i need any special base coat before primer ??
primer 1 coat or 2
colour coat 2 coats enough?
and do i need a clear coat
Posted : 01/04/2009 12:28 am
Couple of coats of primer, 3 at the minimum (thin) coats of colour then a couple of coats of clear lacquer should do the job - rub down lightly with fine wet and dry between each coat. Not a particularly cheap option at £6 per tin - that's almost 20 quid if you can get by with 1 tin of main colour (unlikely).
The [url= http://mamadirt.fotopic.net/p51098758.html ]Chopper[/url] cost me around £35 in paint and my latest project, [url= http://mamadirt.fotopic.net/p56291015.html ]the Dirt Bike[/url], took 3 cans of colour and 1 of lacquer (it had already been powder coated white which served as a nice base coat, saving on the primer). Not cheap but rewarding to think that you've done it yourself - the finish does chip easily though, particularly if not lacquered.
Posted : 01/04/2009 12:40 am
