Sports Massage?
[Closed] Sports Massage?
[#1112838]
This isn't a seedy advert for exotic massage and sensual tickling. I have very short hamstrings, which results in lower back pain after prolonged sports. I've had physio and do all sorts of weird and wonderful stretching but it hasn't helped a huge amount. My physio suggested I try having sports massage. Anyone had it? Does it help? Is it worth the money? Should I just keep torturing myself on door frames instead? Should I buy a new motorbike? (thought I'd sneak that one in).
Ta.
Posted : 08/12/2009 7:04 pm
Yes in a word. Expect it to be painful
Posted : 08/12/2009 7:08 pm
yes , although i only ever found it a short term solution , it relieved the problems for a couple weeks then id have to go back .....
Posted : 08/12/2009 7:12 pm
you'll be fine...
Posted : 08/12/2009 7:13 pm
 Smee
If the stretching isn't working going in and beating the meat is the next option to try. How many times a day are you stretching though? Stretch effects only last around a couple of hours. 😀
Posted : 08/12/2009 7:14 pm
Many moons ago, when I trained 'properly' and was fit 😥 I used to have sports massages once or perhaps twice a week. IME, if you combine them with stretching they work a treat & really help avoid injury. Still seemed to do the trick when i dropped down to one massage per fortnight, but only with regular and thorough stretching to supplement.
If you can find a good massuer, I'd recommend trying it - but as TJ says, expect pain. Good Luck
Posted : 08/12/2009 7:17 pm
I train a lot and use regular sports massage as part of it as well of course as a pious amount of core exercises and stretching 😉
Massage is great although if you have a low pain threshold or are a pussy you may find it unbearable. If you sadistically enjoy pain then you'll be sweet. M
Posted : 08/12/2009 7:24 pm
where are you based i may be able to give you a number for a great physio, gaz
Posted : 08/12/2009 7:30 pm
I used to have it regularly, it was very good. About once a month was enough to keep the muscles supple and stretched.
At first yes, it was very painful but once you go regularly it kind of eases everything out.
Posted : 08/12/2009 7:54 pm
Yes, it helps and it can also be painful 🙂
Posted : 08/12/2009 8:13 pm
 jedi
swear by it
Posted : 08/12/2009 8:19 pm
So the consensus is Yes and ouch. I've got a great Physio but thanks for the offer Gaz, just rubbish hamstring genes. It's weird because it's the only place I lack flexibility.
Posted : 08/12/2009 9:36 pm
