Spoke Replacement o...
[Closed] Spoke Replacement on UST rim
[#2536118]
Hi. I have broken two Marwi Titanium spokes on a Mavic UST Rim. I bought the wheels secound hand before the damage occurred so wasnt responsible for the build.
How to you replace a spoke on a UST rim and does anybody know of a UK supplier for a Marwi Rainbow coloured Titanium spoke.
Allan
Posted : 06/03/2011 5:40 pm
Balfa uk used to supply them.
Posted : 06/03/2011 5:45 pm
If you can remove the broken spoke from the nipple, you can just screw it back on, if not then you need to unscrew the rim-insert using the special tool(Mavic or Park do them, and it's a left hand thread), and replace the nipple with a new 16mm item (take this into account if you're using a spoke calculator, otherwise the spokes will be too long, and may bottom out before tightening fully).
Posted : 06/03/2011 10:23 pm
 mmb
here you go
http://www.chainreactioncycles.com/Models.aspx?ModelID=3842
but this one is what i use and better
http://www.chainreactioncycles.com/Models.aspx?ModelID=18081
Posted : 06/03/2011 10:27 pm
Thanks everybody. No joy set with a uk distributor for the spokes in stock.
[b]
Coatesy[/b]. Can you clarify what you meant when you typed 16mm item. Does that mean a standard nipple 16mm in length. Sorry for my ignorance.
Allan
Posted : 06/03/2011 10:37 pm
