Spoke length questi...
[Closed] Spoke length question
[#2696044]
Hi,
I have bought a superstar singlespeed rear hub and am looking to build it with a Mavic XM 317 rim that I already have. I have done the spoke calcs using the DT Swiss spoke length calcalator and the result is 301mm & 296mm. So should I order 300 or 302mm spokes (301 not an option)? Is shorter or longer better - im guessing 300? Cheers
Posted : 27/04/2011 10:50 am
300mm. longer wont tighten up enough normally.
Posted : 27/04/2011 12:49 pm
 sv
29er rim?
Posted : 27/04/2011 1:45 pm
 mboy
5mm difference from one side to the other sounds a bit extreme!
Usually you have a maximum of 2mm of difference in length from one side to the other. On a proper singlespeed hub, both sides would usually take the same length spokes!
You sure you've done your calculations right?
Posted : 27/04/2011 2:33 pm
Yep, those lengths are totally wrong!!! I misunderstood the meaning of "intersections" on the calculator. Its just a normal 26 rim, and I think I have it right now (much shorter) It will be 3 intersections per spoke.
It's first time wheelbuilding for me, and that will probably be the first of many cock-ups but I am doing it to learn...
cheers
Posted : 27/04/2011 3:05 pm
 sv
[url] http://www.wheelpro.co.uk/spokecalc/ [/url]
I find this easier to use and the book is brilliant.
Posted : 27/04/2011 3:15 pm
