Spider eyes helmet ...
[Closed] Spider eyes helmet light ( bonkers content )
[#2709807]
Bank holiday shed tinkering and experimenting
I give you the spider eyes helmet light throws the furthest down trail I have ever seen .
Its rough and chewed from a lump of alumimium with 2 glass aspherical lenses on board
if used on full then around 2700 lumens leds on board are 2 XMLS and 2 XPGs
Now this is not for the weak of neck as weighs quite a bit
it does mean that when the night riding season comes back that I will be able to annoy my mates from even further back .
beam shot on full but I need to find a longer bit of trail to do it justice and this one is nearly 200 metres long
Posted : 02/05/2011 6:06 pm
At some point the "solar wind" will drive you backwards
Posted : 02/05/2011 6:07 pm
Excellent, keep up the good work Troutie.
Posted : 02/05/2011 6:14 pm
ooh i'd like one of those (unfortunately do not have any cash/my neck muscles aren't that great) do you plan on putting them into production trout?
Posted : 02/05/2011 6:16 pm
TJ as I am in the portly class if I point it backward I get extra thrust from the photon drive .
racefaceec90 this was just a messing about light but I may have tripped over a nice format using 1 of the lenses and a floody one so who knows what will hatch out .
Building a dive light for a mate which was what the aspheric lenses were for as he wants a narrow beam with no side spill so this light was just messing about to see what was possible .
Posted : 02/05/2011 6:28 pm
ah! i do vow on saving up for some of your lights sometime,if you still will be making them? (at present have a hope vision 2 led with the double battery).is a good light,but must admit to wanting (MORE POWER! 😯 😀 i reckon around christmas time i could buy some (am saving for a guitar/amp at present)
Posted : 02/05/2011 6:39 pm
does your helmet have a heat shield built in........
Posted : 02/05/2011 8:04 pm
nope doesnt need one as only the registered blind need full power or a 50 mph downhill
low and medium are excellent High is for when you want to read that road sign 500 metres down the road
though Hi does make a good hand warmer too
Posted : 02/05/2011 8:17 pm
Hmm, what would happen if you made a really narrow beam (say 1cm or less) and aimed that a shed or something similar belonging to someone you don't really like?
Posted : 02/05/2011 8:23 pm
I would like to see a head tube light designed to clamp around the tube. Two lights slightly angled to cover left and right of the tral and one centred on it.
I think it would work nicely.
Posted : 02/05/2011 8:59 pm
Great stuff.
Bike industry needs people like you IMO
Posted : 02/05/2011 9:09 pm
Troutie - is there any mileage in a telescoping flood to throw mechanism like[url= http://www.dealextreme.com/p/c30-flood-to-throw-zooming-glass-optics-cree-p4-wc-100-lumen-led-flashlight-with-strap-3-aaa-18697 ]"low power deal extreme flood throw torch"[/url] ?
Or is it easier to just switch power / leds?
Posted : 02/05/2011 9:13 pm
Quirrel. the downside to mounting the light on the headtube is the dazzle from the cables flapping about in the beam
Stuey I have one of those torches getting reliable sealing for all weather use would be the main bug
Posted : 03/05/2011 6:26 am
You are totally irresponsible, sir! All you will achieve is bankrupting me even more, damn you and your genius!!!
Now, an interest-free option - where do I sign?
Posted : 03/05/2011 6:33 am
Looks good.
It would be cool to seperately connect the 2 smaller LEDs from the main light source to make a lower output level light for map reading etc without blind mates/ melting when stood still. Are they machined to angle light differently to the top two?
Boring technical questions - What model are those LEDs (and cheekily where do you source them - I'm presuming far east not Rapid/RS) and do you use a bought in PWM generator or make your own/ have your own made for you?
Posted : 03/05/2011 7:23 am
Convert
yes I did think about separating the leds for your very reason and also then the spider eyes beam would be a stealth beam with no spill sideways
that would require two drivers and a larger housing 2 switches also
Main leds are Cree XML T6 and the small ones are XPG R2
all from www.cutter.com.au
I wish I had the ability to make my own drivers but no they come from www.taskled.com the driver in this light is the H6Flex
not PWM constant current drivers
the xpgs have wide angled lenses so as to fill the near ground
Posted : 03/05/2011 7:37 am
Nice style, overkill never looked so good!
Posted : 03/05/2011 8:30 am
Thanks for the info - useful potential suppliers. I currently have an A level student's own designed PWM driver circuitboard for a set of blended RGB backlights and main higher powered LED light for a desk lamp in front of me that is not playing nicely that I've promised to give a 2nd set of eyes a look over. As you can see I'm experiencing work avoidance issues!
Posted : 03/05/2011 8:56 am
low and medium are excellent High is for when you want to read that road sign[s] 500 metres down the road[/s] on the moon
Been out in the dark with the pooch and got some long distance beam shots to show
low I am afraid didnt make it to the barn at 160 metres so only got medium and high
went out to 200 metres and the camers didnt get a good pic on low or medium so only hi
managed to get another 100 metres and still get a view of the barn on hi so this is at 300 metres
Pretty darn impressive and my new favourite light 😀
Posted : 03/05/2011 11:45 pm
You really are afraid of the dark 🙂
Posted : 04/05/2011 5:22 am
Not bad. I like the flood and spot idea. But both on at the same time.
Can I buy some of these if you can bar mount them?
Posted : 04/05/2011 5:45 am
Not any more RD but still dont want to get too close to the haunted barn
@ Molegrips am working on a less mental ( only 1800 lumens ) and lighter weight version which may become available in small numbers later on .
Posted : 04/05/2011 7:36 am
The picture of the internals looks like a robotic skull!
Have you ever thought about contacting Hope or someone like that? The machining looks very professional, what batteries do you use? I'm puzzled that more lighting systems don't use the 3.7v Li batteries, I reckon it's inevitable.
Posted : 04/05/2011 7:37 am
Posted : 10/05/2011 9:25 pm
I want one!
Posted : 10/05/2011 9:44 pm
epic machining there, some very nice work.
Posted : 10/05/2011 10:01 pm
Thanks Giantalkali
about 25 hours of painstaking manual milling to get this proto this far .
though well pleased with the result .
Probably take one of the new fangled cnc bods about 20 mins
Posted : 10/05/2011 10:22 pm
judging by the date stamp on your photos, you've burnt a hole in the time-space continuum and accidentally fallen through it.
Posted : 10/05/2011 10:25 pm
Awesome in every sense. WANT! My Hope twin LED's have just given up the ghost too...
Posted : 10/05/2011 10:28 pm
Could you convert this into a death ray?
Posted : 10/05/2011 10:29 pm
OMG, thats mental. It looks like the night sun on the copper chopper shining in that field.
Did it scorch the grass?? Not been round Swinley have you???
Posted : 10/05/2011 10:30 pm
loving the look of the light & the beam, how about some comparison shots with the Liberator as a bench mark?
Posted : 11/05/2011 7:30 am
Is it just me or...
The Trout Light
Splinter Cell
Posted : 11/05/2011 7:41 am
More stuff I want. My Hope Vision 4's are feeling very puny and inadequate now 🙁
Posted : 11/05/2011 8:24 am
awesome work as ever Mr Trout!
Posted : 11/05/2011 8:51 am
Trout - I did sends yo an email about possible motorbike lights - there is a market for this I am sure having discussed it with a few folk
email me (in profile) if you want to carry this further
Posted : 11/05/2011 9:17 am
TJ I was thinking exactly the same thing. my motorbike lights are shoddy and I'd love an upgrade to something like this.
Posted : 11/05/2011 9:56 am
There is an Indian seller on ebay DIY24x7 or something that does bicycle and motorcycle LED lamps 1800 lumens but they do look a bit cheap, but then they are cheap...
Posted : 11/05/2011 10:23 am
thepodge - Member
wouldn't use on motor vehicles require some sort of certification or CE testing ?
Posted : 11/05/2011 11:14 am
Interesting...
(v) Headlamps - the regulations set minimum wattage requirements for dipped and main beam headlamps according to the cubic capacity of motorcycles. Headlamps on motorcycles are not required to have any approval markings, and
(vi) As a general condition the regulations require riders to keep obligatory lamps and reflectors clean and in good working order.
From
Posted : 11/05/2011 1:03 pm
I take that as a no then.
Posted : 11/05/2011 5:29 pm
That looks like a tidy piece of manual machining there Trout.
Good work.
Posted : 11/05/2011 5:53 pm
RC200f8 loving the look of the light & the beam, how about some comparison shots with the Liberator as a bench mark?
OK here are some shots as a comparison .
all on high beam
LIBERATOR (1700 lumens measured )
DX Bastid P7 ( 550 lumens measured )
Triple XML normal optics ( on paper lumens 2700 )
Little helmet light 2 XML ( on paper lumens 1800 )
Spider eyes monster light . ( on paper lumens 2700 )
Posted : 13/05/2011 12:09 am
Trout. Would it be the case that the bulk of the work in one of your lights is in the assembly?
Would it make any sense to offer them in "kit" form with the same profit in it at a reduced price?
Posted : 13/05/2011 12:16 am
Page 1 / 3
