Spicy 2012 Owners
[Closed] Spicy 2012 Owners
[#5486937]
calling Spicy owners
Any one know if the shock extender that connects it to the ost+ uses a bearing or bush. Anyone replaced it an where did you source the spare.
cant find much on Google.
[url= http://sdrv.ms/1al11L2 ]ost > shock extender[/url]
Posted : 05/09/2013 8:27 am
It's definitely a bearing. Size 6900-2RS with a hollow metal pin/rod that goes through the middle. I'm about to do a full bearing swap on my frame, except those two bearings in the shock shuttle as they seem fine for now.
I bought a full set of 2012 Spicy bearings from Kaetec on ebay - he does single bearings too, as do a lot of others on ebay/internet. Just make sure it's decent quality.
The bearings are pressed in from each end of the shuttle so i reckon a punch through from the hole in the middle of the opposite bearing to get them out. And then a 6900 open-bore drift (just found that wheels manufacturing do these in loads of sizes for £5.50ish each - so i've got all 3 sizes for the different bearings in the spicy and a threaded rod to use them with for under £20 - Much cheaper than getting someone else to do it)
Posted : 05/09/2013 4:40 pm
Thanks, took it apart and confirm bearings as you mentioned,I got a few superstar drift tools which should help a lot
What's the bearing size on the lower pivot ?
Posted : 06/09/2013 11:32 am
