guys, do any of you know if a CCDB Air will fit a Spesh Enduro Comp 2010??
cheers
chris
If you managed to get one of the ones off the new 2013 enduro it might but a standard one won't, due to the silly link.
not easily. I modded a coil DB to fit but it was a PITA adapting the standard clevises. If I did it again from scratch I'd get a set of evo links and adapt them as they provide a better mounting interface. You'd be better off just springing for a '13 Enduro with CCDBa as standard.
ok cheers,
its for my brother, does he need a evo link??
new evo frame with ccdb aor is £3k!!
Asked Specialized and also Cane Creek importers who both say it wont fit as 2013 has different mounts
anyone know how much the evo link is and how do u get it?
Any Spesh dealer should be able to get you the enduro evo link but it will not bolt strianght to a db without somersault about
Can you not buy the shock and mount link from Specialized? Are the mounts to the rocker part different? The rocker certainly looks different than my '11 Evo.
Just buying the evo link will not work. This will only enable you to fit the Fox rc2 shox you can buy off specislized.
They are bring out a devolution link which will let you fit a CCDB air to the older frames but there only having a very small amount of them in the UK and there going to be mega expensive !
