Specialized Roval 2...
[Closed] Specialized Roval 29er Wheels any use?
[#4551943]
looking at a second hand setfrom a 2012 epic comp 29er, are they any use, heavy or light... ant info really as it is a bit sparse.
Posted : 12/11/2012 11:04 pm
 mboy
Depends on the spec etc. There's different levels
My 26" Roval Traverse EL wheels have been superb, but then you'd expect that given the quality components used and the original RRP of £600 for the pair!
Posted : 12/11/2012 11:16 pm
pretty OE all info below
RIMS: Roval 29, alloy disc, 26mm wide, 32h
FRONT HUB: Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, 32h
REAR HUB: Specialized Hi Lo disc 142mm, 4x-sealed cartridge bearing, 12mm thru-axle, 32h
SPOKES: DT Swiss Industry, stainless, 14g
Posted : 12/11/2012 11:20 pm
