Specialized Roubaix...
[Closed] Specialized Roubaix disc 2014 - tyre clearance
[#7338445]
Having searched the net to get some info/pics about tyre clearance on my Specialized Roubaix disc (2014) I couldn't find a definitive answer. I was looking to see if cross tyres would fit with enough clearance.
I then tried some schwalbe 35mm cross tyres and they only just fitted the front, but with a bit of rub it was obvious they wouldn't work as soon as I picked up any muck.
The next option was to look at some Schwalbe CX Pro 30mm tyres and I'm pleased to report that these do in fact fit - see the pics for clearance
Just thought I post these up to save others from a fruitless seach for info on this topic......
[url= https://farm1.staticflickr.com/768/21321408688_45bd3e7c00_z.jp g" target="_blank">https://farm1.staticflickr.com/768/21321408688_45bd3e7c00_z.jp g"/> [/img][/url][url= https://flic.kr/p/yu6MYC ]roubaix cx pro front[/url] by [url= https://www.flickr.com/photos/134621616@N08/ ]davey777[/url], on Flickr
[url= https://farm1.staticflickr.com/722/20886479334_4679d89133_z.jp g" target="_blank">https://farm1.staticflickr.com/722/20886479334_4679d89133_z.jp g"/> [/img][/url][url= https://flic.kr/p/xPEECE ]roubaix cx pro rear 2[/url] by [url= https://www.flickr.com/photos/134621616@N08/ ]davey777[/url], on Flickr
[url= https://farm1.staticflickr.com/685/21509249205_f95c53964b_z.jp g" target="_blank">https://farm1.staticflickr.com/685/21509249205_f95c53964b_z.jp g"/> [/img][/url][url= https://flic.kr/p/yLGwqe ]roubaix cx pro rear 1[/url] by [url= https://www.flickr.com/photos/134621616@N08/ ]davey777[/url], on Flickr
Posted : 18/09/2015 11:06 am
Take care - a muddy tyre will slice though a carbon stay like a knife through butter.
Posted : 18/09/2015 11:11 am
Yep, good point, thanks
Reckon I'll heli tape it before taking it out 🙂
Posted : 18/09/2015 11:15 am
You already had the bike, the info you needed was real tyre width, nothing to do with your frame. I'd be surprised if such info wasn't online.
Posted : 18/09/2015 11:18 am
I'm afraid my searches didn't give the answer (hopefully future searches from others will pick up this post). One post said 35's were fine, others said 28 was the max - all a bit contradictory.
And I guess no one posts actual tyre width as it differs depending on the rim it sits on...
Posted : 18/09/2015 11:22 am
The point is you can't rely on the nominal width the tyre is labeled width. You can measure your own frame. The rim makes only a small difference.
Posted : 18/09/2015 11:27 am
True, so out of curiosity I've just measured them with a digital vernier...
width = 30.04mm now that's not bad for a stated 30mm tyre
Also height above the rim would be important for clearance - that's coming out at 31.6mm
Posted : 18/09/2015 11:36 am
It looks very tight though. Why are you trying to fit cyclocross tyres? Would a muddy tyre not block on such a tight gap, or is it not as tight as the photos seem to suggest?
Posted : 18/09/2015 12:17 pm
