Specialized FSR XC Expert, Size Small
The bike is in very good used condition and has been well looked after. It is my daughter’s bike therefore has not been thrashed or ridden hard. She has outgrown it.
The bike does show some signs of use as you would expect and has a small ding on the downtube (see close-up pic) and the seat could do with replacement if you’re fussy.
Full spec below.
£395 collected from near Horsham / Guildford / Weybridge
Any inspection welcome.
Frame: FSR XC M4 tubing with Bolt on cable guides, Sealed cartridge pivot bearings, Replaceable rear derailleur hanger (Disc only) and 120mm travel
Shock: X Fusion 02RC, Custom tuned for Specialized, Rebound adjust, Compression adjust with lock-out, 7.5x1.75 inch, 2 bearing upper shock mount
Fork: RockShox Recon 335 SL, 120mm travel, 32mm alloy stanchions, Alloy steerer, Disc only, Turn Key damper, Rebound adjust with LO, Air spring
Front Derailleur: Shimano Deore, 34.9mm clamp, Top swing, Bottom pull
Rear Derailleur: Shimano Deore XT Shadow, Long cage
Shifters: Shimano Deore LX
Chainset: Shimano FC-M521, Hollowtech
Chainrings: Shimano 22/32/44 Tooth Chainrings
Bottom Bracket: Shimano BB-ES25
Cassette: Shimano HG-50, 9-speed, 11-34 Tooth Range
Front Brake: Avid Juicy 4 RSL Hydraulic Disc Brake, Alloy backed organic brake pads, Tool-less reach adjust
Rear Brake: Avid Juicy 4 RSL Hydraulic Disc Brake, Alloy backed organic brake pads, Tool-less reach adjust
Brake Levers: Avid Juicy 4RSL Hydraulic
Handlebars: Truvativ 35mm rise, butted alloy
Stem: Specialized 3D forged adjustable rise, 31.8mm clamp, 3D forged 105mm Headset:1-1/8 inch Threadless, Loose ball bearings with seals, Black steel cups
Grips: Sunline lock ons
Rims: DT Swiss 445D, disc, 24mm, Double wall, Pin joint, Eyelets, 32 hole
Front Hub: Specialized Hi Lo disc, CNC flange, QR, 32 hole
Rear Hub: Specialized disc, Sealed cartridge bearing, High/low flange with OS contact side, 32 hole
Spokes: 1.8mm (15g) stainless, Black, Alloy nipples
Front Tyre: Maxxis CrossMark
Rear Tyre: Specialized The Captain
Saddle: Specialized
Seatpost: Truvativ, 2-bolt micro adjust (has been shortened to 155mm length)
Seat Binder:Alloy collar with QR, 34.9mm clamp ID
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3960_zpsahd47xaf.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3960_zpsahd47xaf.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3962_zpsud7i2iou.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3962_zpsud7i2iou.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3963_zps0d5ynubl.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3963_zps0d5ynubl.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3961_zpsbzzhpmes.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3961_zpsbzzhpmes.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3959_zpsetvwijpw.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3959_zpsetvwijpw.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3964_zpsfieelwkf.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3964_zpsfieelwkf.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3965_zpsv62ffcnq.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3965_zpsv62ffcnq.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v506/Digger90/IMG_3968_zpsqllsixcz.jp g" target="_blank">
http://img.photobucket.com/albums/v506/Digger90/IMG_3968_zpsqllsixcz.jp g"/> [/IMG][/URL]
