Anyone know where i can get a bushings kit for an '09 Stumpy FSR?
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=92&Name=Strong+Bushes ]BETD[/url]
same bearings as BETD but I got mine direct from the states (relworldcycling, Max complement bearings make sense for pivots)as I had a mate on hols over there.
Onza - he said bushing kit for the shock (I presume) not Bearing kit?
Sorry, my mistake. If the top hats are okay, then pretty much any bike shop with its salt could replace the du bush.
Cheers for the replies folks. Its just the shock bushings that need replaced, bearings are all 100%. Just not sure what size i need, thats the only issue.
1/2 inch Fox bushing I presume its a fox Float?
depends on the manufacturer of the shock
Fox = 1/2 inch. I think the code is DU08 for it. Basically just look on tftunedshox.com for the ones which match your shock.
The shock is a Fox Triad (custom for Spesh i think). I'll need to measure it up once i have it removed.
No measuring needed. if it's Fox, it's a half inch DU bush.
Onza - you have to replace the inner and the liner - so he needs to measure the diameter of the axle and Bolt to order the right kit from BETD 🙂 Yes Fox are 1/2 inch diam std but... 😉
