Specialized Enduro ...
[Closed] Specialized Enduro '08 Front Suspension Upgrade
[#2230853]
I have an Enduro with the Specialized E-150 tripple clamp forks with the 25 mm axle. They kill me. There is little or no small bump responce. I've had a set service and even bought another set to see if there was a difference. I just can't seam to set them up properly.
What is the best alternative ?
I have a spare front wheel that i can have the hub replaced on so I guess I'm after a new front fork and hub.
Any suggestions please ?
Posted : 27/11/2010 9:20 pm
revelation 150mm maxles?
Posted : 27/11/2010 9:22 pm
Revelation Teams if you want light, 36s or Lyriks if you want grr. Sorted.
Posted : 27/11/2010 9:23 pm
Have you fiddled with the spike valve pressure?
Posted : 27/11/2010 9:37 pm
Have a real good read through [url= http://forums.mtbr.com/showthread.php?p=3935127 ]this thread[/url] mate, if you're reasonably confident with servicing your own fork (it isn't hard) then there's a ton of great info in there... the E150 is a top fork, but it does need a bit of work to get the best out of it (but them, so do a lot of forks tbh).
Posted : 27/11/2010 9:54 pm
Cheers guys.
Whats this slick honey stuff ?
Posted : 27/11/2010 11:24 pm
Super slippy grease
Posted : 27/11/2010 11:27 pm
Lyrik.
Preferably coil.
GRR!
Posted : 28/11/2010 12:39 am
That looks like the answer to me.
Is it just a change of front hub or are there other things I need to do (stem , bars etc.) ?
Oh yes ...........GRRRR indeed !
Posted : 28/11/2010 9:55 am
You'll need a new stem and hub.
Posted : 28/11/2010 11:31 am
