Specialized 'D...
[Closed] Specialized 'Dangler'
[#3125101]
[url= http://bikemagic.com/gear/first-looks/eurobike-2011-specializeds-2012-mountain-bikes.html ]Is it me?[/url]
[url= http://www.crudproducts.com/history/1993 ]nearly 20 years ago:[/url]
Posted : 07/09/2011 8:48 pm
Yes they seem to have (re)invented the DCD (Dave's Chain Device. I expect the patent has run out on the original now. If it's that good, why did everyone stop using them the first time round though?
Posted : 07/09/2011 8:53 pm
I have an ano purple one in the garage. I dont think it will be going on the bike though.
Posted : 07/09/2011 9:00 pm
[i]why did everyone stop using them the first time round though?[/i]
Because many of us realised they were solving a problem that wasn't really there anyway.
Posted : 07/09/2011 9:04 pm
gimmick
Posted : 07/09/2011 9:19 pm
 aP
But that's H-ball, they must be good if colourful.
Posted : 07/09/2011 9:20 pm
people have been doing chainstay mounted devices long since the dcd disappeared.
Posted : 07/09/2011 9:27 pm
Oo look another place for mud to get stuck.
Posted : 07/09/2011 9:58 pm
That DCD is on back to front, isn't it?
I stopped using mine when alu frames came in with their bigger chainstays
Posted : 07/09/2011 10:20 pm
But will the Dangler make as cool a noise as the DCD?
That one in the photo does appear to be the wrong way round
Posted : 07/09/2011 10:29 pm
H-Ball FTW! 🙂
Posted : 07/09/2011 10:30 pm
That's an impressively long rear mech cable on the retro pic
Posted : 08/09/2011 8:19 am
Thats because it's a [i]suspension[/i] bike. They need all that cable for the massive rear wheel articulation
I prefer the [url= http://www.bionicon.com/home/309-interview-with-dirk-luede-the-cguide-inventor ]Bionicon[/url] one [img] [/img]
Posted : 08/09/2011 8:59 am
its very nice and simple but won't fit my frame due to seatstay cable routing
Posted : 08/09/2011 9:18 am
The new one should. If they ever become available. http://www.bionicon.com/ac/c-guide-v02
I need something for my new Giant Reign which despite having 6" travel has no means of fitting a chain device. Aaaaah!
Posted : 17/09/2011 8:54 am
I'm considering paying extra for the XTR clutch rear mech and seeing if that negates the need for another chain device.
It seems like a better place to do it.
The only problem is I would be much more careful going through narrow gaps from then on.
Posted : 17/09/2011 10:07 am
Hmm, not sure I could stomach shelling out £160 when I have a perfectly good XT mech on my bike right now.
I saw a cheaper solution on a forum:
https://picasaweb.google.com/112995870409096219692/Rozne?gsessionid=LZQ3UYcYFaLg2T6Nb3f6pQ#5615188562934992658
Posted : 17/09/2011 9:06 pm
I'm still not seeing why this is an issue.
Posted : 17/09/2011 10:36 pm
Because I want to do a bit of UK dh and maybe take my bike to the Alps next Summer.
Posted : 18/09/2011 9:01 am
XTR £120,70 + shipping from rose bikes.
Hopefully they'll come out with an XT level version that is more affordable. If they were <£60 then it would look attractive against all those overpriced E13/MRP chainguides.
Posted : 18/09/2011 9:38 am
 jonb
ugly but there is this on CRC
http://www.chainreactioncycles.com/Models.aspx?ModelID=10137
considered seeing if I could use one to go SS as it might be tougher than a rear tensioner.
Posted : 18/09/2011 12:35 pm
Becuase they had other options for fitting chain devices, if they needed them?
That looks to my uneducated eye like it would create more drag than a BB/ISCG mounted device closer to the chainset.
But as the Reign owner above suggests, several bike companies are now making long-ish travel bikes with press fit BBs, no ISCG tabs and weird seat tubes - ruling out most available chain devices.
Posted : 18/09/2011 1:13 pm
Why not just get the right chain length and / or an xtr trail mech?
Posted : 18/09/2011 2:19 pm
 Olly
cant you use a BB fitted type?
back plate replaces one of the HTII BB spacers...
Posted : 18/09/2011 2:23 pm
BB mounted chain devices don't work on press fit bottom brackets. You can't get enough pressure to stop it spinning.
I saw on another forum, someone had used one of the CRC Ging chain tensioners with a bash ring and a bit of moulded plastic bolted onto the front derailleur mount. A lot of bodging.
I don't mind a bit of bodging, I'm just surprised Giant failed to see this problem when designing the bike. I already had to bodge a piece of rubber between the rear gear and brake cables to stop them rubbing on the shock stancion.
Suspect it comes down to a few $.
Posted : 18/09/2011 11:16 pm
So use iscg tabs?
Frames with no iscg and pressfit? Way to make shit awkward.
Posted : 18/09/2011 11:24 pm
