I have just got and installed a blacklite dropper post on my bike. seems to work well apart from when you press the lever to return back up to the top it stops just a bit from the top (10 - 20 mm, not in the mid locked position however 35mm from top ). It is as if the air spring pressure is not great enough to return the post to its top position, i am reluctant to add more air as i think 40psi is the maximum? i cant see how cable tension would affect this problem?
Posted : 26/12/2012 11:51 pm
