spare parts for Roc...
[Closed] spare parts for Rock Shox fork
[#2790239]
I have a Lyrik IS two step, and i have lost the cone nut thing and the screw cap for the end of my thru axle. they have obviously flown off when i was taking my wheels off to put my bike in the car, but i didnt realise till i got home! 🙁
Will/where can i buy replacement parts for these? ta
Posted : 26/05/2011 9:09 am
try petra cycles
www.petra.co.uk
They have a huge range of fork spares, got a CSU from them a while back and top service.
Posted : 26/05/2011 1:01 pm
tft will help you out. give them a call. http://www.tftunedshox.com/
Posted : 26/05/2011 1:02 pm
Try Loco Tuning? Simon is on here quite often.
Posted : 26/05/2011 1:05 pm
 LoCo
Afternoon 😀
wedge kit?, maxle or maxle lite? 😉
Posted : 26/05/2011 1:06 pm
err... mightymarmite, thats a link to a genealogy website i think you meant http://www.petracycles.co.uk/... seems to be only place in britain that stocks rockshox dampers too
Posted : 26/05/2011 3:20 pm
 LoCo
umm...
Posted : 26/05/2011 3:24 pm
Petra have been spot on for of my needs with odd ball rockshox bits used in 29er frankenfork builds.
Posted : 26/05/2011 3:26 pm
[b]LoCo[/b]
Posted : 26/05/2011 3:30 pm
 grum
Loco - while you're here.....
I have some coil Pikes where the lockout no longer works, and they only get about halfway down the travel without stopping (even with no spring in). I gather it's probably oil leaked into the wrong bit on the non-coil side or something?
What bits do I need to sort it out and can you sell me them? 🙂
Posted : 26/05/2011 3:39 pm
wedge kit eh? that sounds about right - stone me, £30!?
think ill just get a couple of washers out of me tool box... 😉
Posted : 26/05/2011 3:42 pm
 LoCo
Grum, have the seals for the seal head (bottom of damperside upper leg) jusy change those and the oil, off to post office in a mo drop me a line and I'll pop some in the post.
Jaffe, Rockshox isn't cheap is it?! Although it would be a little cheaper than that 😉
Posted : 26/05/2011 3:52 pm
is that definitely what i need then? im a thru axle novice. ill buy it off you no problem. cant see one in your site tho..?
is this a common problem?
Posted : 26/05/2011 4:03 pm
I wondered why my forks kept shouting "freedom" and turning a weird blue colour after I fitted the CSU ???
Posted : 26/05/2011 4:11 pm
 LoCo
Jaffe, yes it's everything apart from the actual axle itself, the amount of parts that could be listed for Rockshox alone not to mention the other brands I deal with would in itself be a full time job hence no listing. So it's always best to call for parts like that.
I need to know whether it's a maxle or maxle lite.
Marmite, sounds like a warranty issue best return the component to place of purchase for an inspection 😉
Right now to fit some new wheels and tyres on the bike 😀 Will be in the workshop till about 5.30 if you need any advice.
Posted : 26/05/2011 4:39 pm
