Spacing out inner c...
[Closed] Spacing out inner chainring for M970 fit
[#3561493]
Xtr 970 has an inner ring which is way thicker than the steel SLX one i am about to replace it with. Any ideas on how many mm of spacers to add. Or just line both up and add by eye. Intend to use disk shims.
Posted : 13/01/2012 4:15 pm
W,
Measure the middle-outer spacing and go for the same for the inner-middle.
Disc calliper shims are for 5mm bolts, chainrings are 8mm bolts so I think you may have some dremelling to do!
Normal 8mm washers of approx 0.75mm thickness will probably be near enough.
PaulD
Posted : 13/01/2012 4:20 pm
2mm is the spacing you need and rotor shims won't fit. You need these:
http://www.pro-bolt.com/aluminium/aluminium-nuts-washers.html?cat=778&thread_washer_dia=164
Choice of colours too!
Posted : 13/01/2012 4:47 pm
