Spacers to make an ...
[Closed] Spacers to make an old wheel fit a frame/fork
[#5536967]
Probably a daft question but...
Putting together winter singlespeed and as the frame doesn't have disk mounts i'm having to use an old set of rim brake wheels I had kicking about.
Unfortunately the hubs are to narrow (although I've replaced the axle so that fits), can I just use bolts and washers as spacers to make it fit?
Posted : 21/09/2013 1:05 pm
I don't understand...firstly all mtbs from 1990 have the same spacing for QR hubs, secondly I can see how washers would make spacers, but bolts?
Though all you need to make up any space is a washer or similar, yes, and make sure the axle is engaging in the dropout.
Posted : 21/09/2013 1:09 pm
Will assume a typo bolts=nuts 🙂
Got any old cup and cone axle washer's/spacers ? i used them with inboard chaintugs to space out a 700c wheel into a KM frame.
Did see an awful death trap job where the owner had respaced a free wheel hub to run a single speed only, couple inch's of spacers and washer's.
It can be done safely.
Posted : 21/09/2013 1:17 pm
