Sourcing cheap(er) ...
[Closed] Sourcing cheap(er) bearings for American Classic hubs?
[#3208437]
Looks like I need some 17mm 6803 bearings (so I'm told) 😉
Seem to be about a tenner each on bike sites, but there seem to be cheaper 6803-prefixed bearings on ebay a lot cheaper.
Are these going to work - if so, which sort?
These any good? http://www.ebay.co.uk/itm/6803-2RS-61803-2RS-PACK-5-THIN-BEARING-17-X-26-X5MM-/220453446058?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item33540ca1aa
Ta
Rich
Posted : 03/10/2011 10:54 pm
You want good quality branded ones, FAG, SKF etc. cheapo ones have less good seals and will not last as long
Posted : 04/10/2011 6:12 am
Point taken - there's SKF ones one ebay I think. I was just wondering if any 6803-prefixed bearings work, or if I need something specific?
Posted : 04/10/2011 7:58 am
The bearing number is universal. a 6803 bearing is a 6803 bearing
Posted : 04/10/2011 8:02 am
A2Z hubs are exact copies of Am Classics. They do a pack of 4 for about £25. I don't think they are 61803's Iirc though.
Posted : 04/10/2011 8:12 am
The freehub is different on A2Zs, and I'd not be certain the axle's the same diameter, so I wouldn't like to say if the bearings are the same. But in answer to your question: yes, as above any 6803 will work. The suffix relates to the sealing; you ideally want 6803-2RS which have 2 rubber seals, as opposed to metal shields or whatever.
Posted : 04/10/2011 8:33 am
I get most of my bearings from RS Bearings in Dundee.
They do 'em [url= http://www.bearings-online.co.uk/item/Brand_Deep-Groove-Ball-Bearings_61803-2RS_0_0_142_0.html ]here[/url] for £3.73 for the 2RS version.
Posted : 04/10/2011 8:39 am
Thanks for the advice folks.
Namastebuzz - those ones are 61803 rather than 6803 - does that make a difference?
Posted : 04/10/2011 8:59 am
No I think it's just their numbering system - all the dimensions are the same as 6803s I've seen listed.
26x17x5mm.
As I say - I've ordered loads off them and the quality/seals seem good.
Posted : 04/10/2011 11:02 am
