Sorry tyres again.....
[Closed] Sorry tyres again...
[#1895349]
What tyre for wet pine needles with mud undeneath. Wet rocks and wet roots.
I'm using and advantage 2.25 on front recently and that had been ace in the dry but today it was lethal.
High roller 2.35 folding super tacky? Keep advantage on rear?
Posted : 14/08/2010 11:39 pm
Maxxis don't do a 2.35" high roller folding 42a, they only do it in wire bead
A 2.35 high roller is also smaller than a 2.25" advantage too, so a bit odd 2.35" HR front, 2.25" advantage rear
What tyre pressure do you have your advantage, I found dropping from 40 to 35psi improved the grip (especially cornering) volumes
Which compound is it also? 70a or 60a?
Posted : 15/08/2010 12:48 am
From recommendations on here, I went tubeless with conti RQs.
The people are correct; the tyres are brilliant particularly in corners.
Mine don't even have the black chili which are believed to be even better.
Believe the hype dude.
Wanring; the 2.2s are as big as my old blue groove 2.35s.
Posted : 15/08/2010 12:54 am
