I know it's been done a million times before. But I'm struggling with how much I need from a tyre. Hopefully someone else has tried something that fits current criteria:
Criteria is:
For mud, sand, gravel, tarmac and rocks. Tubeless and cheap. 26". Cheap.
I currently have rocket ron/smart sam on but now I'm starting to explore the peaks on heavier ground a little more the sam is up to the heavier ground.
2 of them
Minions win everything
They that good? I've never had Minions, only Ardent/Ardent Race
Yep, can't beat Minion's for all round use. Maybe stick a 3C on the front if you can..
At the moment I have minion 3c and ardent 2.4 on the back. I'm. Not an overthinker it helps, though I do think a bit waiting for them....
Minions on tarmac 😯
Hope the OP has thighs of steel and the lungs of a horse
No I do not. I use the whippet to commute too, only 5 miles a day though.
Decathlon do hutchinson and michelin tyres that are decent - doubt you would find cheaper. Not a huge range, but they will have some 26 tubeless ready.
I've been impressed with Spesh ground control as good all-rounders. Not even sure they're meant to be, but after about 10 years of blindly using high rollers it was a +ve change.
Spesh Purgs are a good all rounder i find and £20 at the mo from some site. Was a PSA on them last week. Hargreaves cycles maybe?
i've got the ground control sport.. really good & cheap. surprised i haven't punctured the sidewall yet. lasted pretty well so far after installing them in the new year. they're wearing nicely with the ground conditions 🙂
next tyre i'm looking for something slightly bigger for this winter. purgatory might be it. so thanks 🙂
Landcruisers.
Bloody minefield this! Anyone used rock razors?
High Rollers are a good all rounder, as are Hans Dampf.
