Sonder Broken Road ...
[Closed] Sonder Broken Road V2 rear axle thread pitch?
[#12393855]
Long story short, I stripped my rear axle. Luckily I managed to get it off with a bit of lubricant, hammer and a torx head. Ordered a good torque wrench right after, but now I'm without a rear axle and I don't know the right (thread) dimensions. It's a 148mm boost frame.
I measured the axle and it is 180mm from the base of the head to the end of the threads, with 12mm diameter and 20mm thread length. I assume I still need to know the exact thread pitch but I have no tools to measure it.
I live in a remote place in northern Finland and I have no access to a LBS so I have to order online. Is there anyone out there who would know the thread pitch of a stock rear axle?
Posted : 24/05/2022 5:50 pm
Does it not say on the axle you took out? I did the same on a previous frame and luckily it was all printed on the axle.
Unfortunately the replacement I ordered from wiggle was described wrong in their website and had a different thread pitch when it arrived. Managed to buy a brand x I think in the end that was correct.
Could you order 2 (or more) online with same dimensions but differing thread pitches, keep the one that fits and return the others for refunds?
Edit: forgot about this-
https://robertaxleproject.com/
Posted : 24/05/2022 5:56 pm
There is nothing printed on the axle, sadly. I checked
https://robertaxleproject.com/but the only Sonder frame the database has is Transmitter. I could order a couple of axles but returning items usually costs and is a hassle.
Posted : 24/05/2022 6:04 pm
Print off the axle measurer on their website? If you click not listed on the axle finder it takes you to the page…
Posted : 24/05/2022 6:06 pm
Email AlpKit?
Posted : 24/05/2022 6:11 pm
Actually yes that is the obvious answer!
Posted : 24/05/2022 6:13 pm
Didn't know about the printable measurer, looks nice! I don't have a printer but I'll try to ask everyone I know if they have one.
edit: should have added that I emailed Alpkit a week ago but haven't received an answer.
Posted : 24/05/2022 6:17 pm
I have a Titus Mutsu which is the On One copy and that uses a 1.75mm pitch.
I've recently ordered a replacement from Wiggle as I realised my multi-tool doesn't have a Torx bolt head around that's the correct size:
12mm bolt thru axle
Posted : 24/05/2022 10:03 pm
Here’s what alpkit told me when I asked them for my Broken Road (I think v2).
180mm total length with 20mm of thread. 1.75p thread
Interestingly I did email Robert axle to give them the data and they responded to thank me so I’m surprised it’s not on their database
Posted : 24/05/2022 11:33 pm
