Solutions to Magics...
[Closed] Solutions to Magicshine vibrate/shake on the bars?
 jlc
[#2024983]
Tried the lights and there is some vibration/shake causing a strobe effect on rough terrain? Just wonder if there are any solutions people have come up with to solve this. Any help would be much appreciated. Thanks
Posted : 25/09/2010 10:10 am
there was a thread about a day or 2 ago with a replacement mounting
Posted : 25/09/2010 10:24 am
 jlc
Had a quick look and could not find the thread. Any further suggestions? Thanks
Posted : 27/09/2010 1:58 pm
only cycle on the road ?
Posted : 27/09/2010 1:59 pm
Search for "magicshine clamp" HTH and cycling on the road that's perverse 😉
Posted : 27/09/2010 2:13 pm
I just cable tied mine to the bars. Sorted.
Posted : 27/09/2010 2:20 pm
Insulation tape and zip ties. My bodge of choice for most bike related issues.
Posted : 27/09/2010 2:27 pm
I have this problem too....
it's not just strobe/wobble you need to be careful of... there is a single small screw holding the light onto its plastic bracket which loves to jump out mid ride.
I have been hoping someone could suggest a "surrogate" bracket which would fit the light and be a lot more sturdy?
or can I get a new bracket fabricated by any kind tinkers on here?
Posted : 27/09/2010 2:50 pm
 cp
Ax3M4n - go through the magicshine threads, a surrogate bracket has been suggested in the form of a partial Electron bracket from chain reaction.
Posted : 27/09/2010 2:54 pm
The bottom of page 90 of this thread has a good idea that I based my fix on:
http://www.bikeradar.com/forums/viewtopic.php?t=12660192
I got the £3 bracket from here: http://tinyurl.com/33o2y7p
I used part of the top price too though as it allows the light head to rotate to cater for bar sweep. Hacksaw required.
Edit: Too slow - Jamies link refers to the same fix.
Posted : 27/09/2010 3:00 pm
I used a piece of rubber under the mount so it holds a bit firmer. Also worth checking is the screw that screws the mount to the lamp unit. Mine sometimes get a bit loose and the light starts to wobble a bit no matter how tight the o ring on the clamp is.
Posted : 27/09/2010 3:03 pm
Is the light actually turning on and off due to the vibration?
If so that sounds more serious than just a new mount.
Posted : 27/09/2010 3:19 pm
I took the mount off my old lumicycle lamp and screwed it into the magicshine lamp. perfect
you can get them here
[url] http://www.lumicycle.com/product/214/qr_cam/qr-camlock-bracket.html [/url] for 8 quid.
no hacksaw required.
