Contemplating some of those 9mm superstar skewers.
What bits do I need to convert my hubs.
Just using conventional qr at the moment.
First things first, you need to look for a 9mm front axle and 10mm rear, these are the standard sizes a QR frame and fork will take.
You mean Pro2 Evo hubs, right?
All you need is new adapter inserts.
Front 9mm: http://www.chainreactioncycles.com/hope-pro-2-conversion-kit-9mm/rp-prod40654
Rear 10mm: http://www.chainreactioncycles.com/hope-pro-2-evo-rear-hub-conversion-kit/rp-prod68578
Make sure you select the 10mm Bolt Thru for the rear one as the option.
Ta.
Fork dropouts can only take 9mm axles, whereas rear dropouts can take 10mm axles. So, as Rusty Mac says, you will need a 9mm front axle and a 10mm rear.
Just to reiterate daniel groves reiteration of rusty mac's comment 😉
