I bought mine from the original thread, bit worried now.
Which charger is it off the link above? Does that definitely have the right connecter for the head unit?
I'll get a battery too from torchy if someone can link it?
The 'fuse' will be the fusible resistor next to L at the top. As an engineer I would prefer to see a certified wire ended fuse soldered in there. Probably costs a few more pennies though.
Frankly I'm more concerned about how good the isolation is between mains and the charger connections.
daveatextremistsdotcouk do you still want a pic of the fused one?
or this fluxient at £89 with big, waterproof, battery:
Colour blindness sux 🙁 20 Ohm +/-5%?
The pic you put up earlier shows what looks like a wire ended glass fuse. Slightly different design from a different sweatshop was my thought.
