I've got a Soalris frame and have some SLX M675 brakes, what do i need to mount the rear brake (i'll be using a 160mm rotor). I assumed it was a Post to IS 160 mount, i have one of those lying around somewhere.
The mount on the frame doesn't have any threads and the bolts i have are the wrong diameter.
The threads should be in your adaptor, not in the frame
It's a standard mount - nothing odd about it
I have 160 mm slx brakes on mine - and just use the standard adaptor that came with the brakes
Its a IS mount. you'll need a IS to PM 160mm
some thing like a type1 on here
the M5 bolts pass through the frame and screw in to the mount.
okdokey, ta for quick responses, think i was having a blonde moment, got it fitted;
[URL= http://i1176.photobucket.com/albums/x325/hadyadaya/photo_zps557a4dd6.jp g" target="_blank">
http://i1176.photobucket.com/albums/x325/hadyadaya/photo_zps557a4dd6.jp g"/> [/IMG][/URL]
thats the kiddy.
Toptip run a short length of tap on the inside of the chain stay where the rotor will scratch the paint off, might just be a 180mm rotor thing but worth doing.
if you are running a front mech which one have you gone for?
Oh and you'll love it.
[url= https://farm6.staticflickr.com/5547/12701151805_559baf8092.jp g" target="_blank">https://farm6.staticflickr.com/5547/12701151805_559baf8092.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/16701462@N03/12701151805/ ]P2221308[/url] by [url= https://www.flickr.com/people/16701462@N03/ ]paul.sal[/url], on Flickr
Ta for tips. Am going 1x10 Zee shadow plus, blackspire NW, XT crank and shifter. I'm in the process of heli taping the at risk areas before I start building. Ran out of tape. Lmao, new stuff on way from CRC!
