So I was about to g...
[Closed] So I was about to go out and ..... no drive from the rear hub ?
[#5475140]
It was ok the other night but I knew that there was some play in the rear hub ( I could feel the slight movement in the rear wheel ) but this morning all kitted up, Strava started on the bike and pedal but no forward movement !
I could spin the pedals both ways without any drive, I'm no bike mechanic but does this mean the freehub is b*ggered ?
The freehub is less than a year old and has only done about 1000 miles - that doesn't sound much to me !
Any ideas - it will be going to the LBS - I won't be attempting to fix it, I'm just wondering what the problem is and if that's normal wear and tear ?
Posted : 01/09/2013 9:20 am
What hub is it? Many of them are a piece of p*ss to take apart and have a look
Posted : 01/09/2013 9:22 am
pawls or pawl springs
Posted : 01/09/2013 9:25 am
Spray copious amounts of WD40 around it whilst spinning it, nothing to loose.
Not frozen is it???
Posted : 01/09/2013 9:35 am
there's your problem 😉
It's easy to take apart if it's hope or the like - probably a sticky pawl - or it may be that some water has got into the freehub and the pawls have stuck in place. Very easy to fix.
 br
[i]I won't be attempting to fix it, I'm just wondering what the problem is and if that's normal wear and tear ? [/i]
Why not? Just take it apart and you'll see why it doesn't work. Then ask us how to fix it.
Next time, you'll know and be more prepared.
Posted : 01/09/2013 9:38 am
That's Loads/Not a lot/some/quite a bit/hardly anything - mountain biking doesn't go by the numbers like road bikes, it depends what, how & where you road how good/bad the seals are and some luck.
Whats the hub might be a 2 minute job.
I had a DTSwiss hub OEM AM1700 for Canyon where the freebub barrel began to rotate within the ratchet piece thingy . It was a clintch fit only. New hub in steel ok now but a poor design. Needed higher torque, got worse in the cold & was hard to track down.
Posted : 01/09/2013 9:41 am
Posted : 01/09/2013 9:44 am
